Uh, I’m only seeing 6 tests on this program.
for i in {1..18}; do
echo "Running RAMSMP -b $i"
./ramsmp -b $i
done
Running RAMSMP -b 1
RAMspeed/SMP (GENERIC) v3.5.0 by Rhett M. Hollander and Paul V. Bolotoff, 2002-09
8Gb per pass mode, 2 processes
INTEGER & WRITING 1 Kb block: 53210.52 MB/s
INTEGER & WRITING 2 Kb block: 52210.12 MB/s
INTEGER & WRITING 4 Kb block: 55457.66 MB/s
INTEGER & WRITING 8 Kb block: 55248.02 MB/s
INTEGER & WRITING 16 Kb block: 55340.12 MB/s
INTEGER & WRITING 32 Kb block: 54031.71 MB/s
INTEGER & WRITING 64 Kb block: 49063.05 MB/s
INTEGER & WRITING 128 Kb block: 48978.01 MB/s
INTEGER & WRITING 256 Kb block: 46856.64 MB/s
INTEGER & WRITING 512 Kb block: 40126.71 MB/s
INTEGER & WRITING 1024 Kb block: 39826.43 MB/s
INTEGER & WRITING 2048 Kb block: 34352.73 MB/s
INTEGER & WRITING 4096 Kb block: 10125.62 MB/s
INTEGER & WRITING 8192 Kb block: 7456.10 MB/s
INTEGER & WRITING 16384 Kb block: 7368.10 MB/s
INTEGER & WRITING 32768 Kb block: 7405.88 MB/s
Running RAMSMP -b 2
INTEGER & READING 1 Kb block: 104948.88 MB/s
INTEGER & READING 2 Kb block: 106476.78 MB/s
INTEGER & READING 4 Kb block: 106960.38 MB/s
INTEGER & READING 8 Kb block: 105023.30 MB/s
INTEGER & READING 16 Kb block: 103793.00 MB/s
INTEGER & READING 32 Kb block: 95564.50 MB/s
INTEGER & READING 64 Kb block: 76146.84 MB/s
INTEGER & READING 128 Kb block: 77423.42 MB/s
INTEGER & READING 256 Kb block: 70756.85 MB/s
INTEGER & READING 512 Kb block: 59174.71 MB/s
INTEGER & READING 1024 Kb block: 55862.14 MB/s
INTEGER & READING 2048 Kb block: 52304.54 MB/s
INTEGER & READING 4096 Kb block: 22492.42 MB/s
INTEGER & READING 8192 Kb block: 15089.98 MB/s
INTEGER & READING 16384 Kb block: 14834.31 MB/s
INTEGER & READING 32768 Kb block: 14892.55 MB/s
Running RAMSMP -b 3
INTEGER Copy: 10080.25 MB/s
INTEGER Scale: 10017.43 MB/s
INTEGER Add: 11145.15 MB/s
INTEGER Triad: 11073.91 MB/s
INTEGER AVERAGE: 10579.18 MB/s
Running RAMSMP -b 4
FL-POINT & WRITING 1 Kb block: 47777.87 MB/s
FL-POINT & WRITING 2 Kb block: 49401.94 MB/s
FL-POINT & WRITING 4 Kb block: 49703.01 MB/s
FL-POINT & WRITING 8 Kb block: 48970.96 MB/s
FL-POINT & WRITING 16 Kb block: 51168.86 MB/s
FL-POINT & WRITING 32 Kb block: 47462.53 MB/s
FL-POINT & WRITING 64 Kb block: 44278.07 MB/s
FL-POINT & WRITING 128 Kb block: 42340.29 MB/s
FL-POINT & WRITING 256 Kb block: 42285.84 MB/s
FL-POINT & WRITING 512 Kb block: 40267.36 MB/s
FL-POINT & WRITING 1024 Kb block: 37078.76 MB/s
FL-POINT & WRITING 2048 Kb block: 36983.61 MB/s
FL-POINT & WRITING 4096 Kb block: 11702.55 MB/s
FL-POINT & WRITING 8192 Kb block: 7722.04 MB/s
FL-POINT & WRITING 16384 Kb block: 7648.96 MB/s
FL-POINT & WRITING 32768 Kb block: 7631.74 MB/s
Running RAMSMP -b 5
FL-POINT & READING 1 Kb block: 103747.56 MB/s
FL-POINT & READING 2 Kb block: 104764.24 MB/s
FL-POINT & READING 4 Kb block: 107648.35 MB/s
FL-POINT & READING 8 Kb block: 107919.85 MB/s
FL-POINT & READING 16 Kb block: 108481.03 MB/s
FL-POINT & READING 32 Kb block: 98321.25 MB/s
FL-POINT & READING 64 Kb block: 78810.90 MB/s
FL-POINT & READING 128 Kb block: 70011.90 MB/s
FL-POINT & READING 256 Kb block: 68655.90 MB/s
FL-POINT & READING 512 Kb block: 58248.49 MB/s
FL-POINT & READING 1024 Kb block: 58312.26 MB/s
FL-POINT & READING 2048 Kb block: 52684.28 MB/s
FL-POINT & READING 4096 Kb block: 23211.62 MB/s
FL-POINT & READING 8192 Kb block: 15187.99 MB/s
FL-POINT & READING 16384 Kb block: 15030.19 MB/s
FL-POINT & READING 32768 Kb block: 15121.26 MB/s
Running RAMSMP -b 6
FL-POINT Copy: 9976.21 MB/s
FL-POINT Scale: 9938.54 MB/s
FL-POINT Add: 11143.39 MB/s
FL-POINT Triad: 11039.87 MB/s
FL-POINT AVERAGE: 10524.50 MB/s
Running RAMSMP -b 7
USAGE: ramsmp -b ID [-g size] [-m size] [-l runs] [-p processes]
-b runs a specified benchmark (by an ID number):
1 -- INTmark [writing] 4 -- FLOATmark [writing]
2 -- INTmark [reading] 5 -- FLOATmark [reading]
3 -- INTmem 6 -- FLOATmem
-g specifies a # of Gbytes per pass (default is 8)
-m specifies a # of Mbytes per array (default is 32)
-l enables the BatchRun mode (for *mem benchmarks only),
and specifies a # of runs (suggested is 5)
-p specifies a # of processes to spawn (default is 2)
-r displays speeds in real megabytes per second (default: decimal)
ERROR: unknown benchmark ID
Running RAMSMP -b 8
Running RAMSMP -b 9
Running RAMSMP -b 10
Running RAMSMP -b 11
Running RAMSMP -b 12
Running RAMSMP -b 13
Running RAMSMP -b 14
Running RAMSMP -b 15
Running RAMSMP -b 16
Running RAMSMP -b 17
Running RAMSMP -b 18
