Need sugestions on configuring airflow in/on a Corsair 500R
So I decided to now take the easy way out and I ordered a Corsair 500R and due to the way the h110 fits in it (fans on top) I had/have two ideas for for fan configuration and they are:
Option 1
2X 140mm top fans (above the H110) as intake ie pushing through the H110
2X 120mm front fans as intake
1X 200mm side fan as exhaust
1X 120mm fan rear as exhaust
OR
Option 2
2X 140mm top fans (above the H110) as exhaust ie pulling through the H110
1X 200mm side fan as intake
So which one would work best do you guys think? also feel free to make any other suggestions on a configuration.
Top: exhaust.  Front: intakes.  Side: intake.  Rear: exhaust.
