Hi everyone I am fairly new to this but here we go i need some opinions on this build I want to do here are the parts i plan to buy
AMD FX-8320 8-core Black Edition
Gigabyte GA-78 LMT
GX Cooler Master 650W
Adata XPG 8gb ram
I also have a GTX 500 1gb that i might want to use but i do plan on getting a ASUS 7850
I also have western digital hardrive
I just want to know if this is a good setup? should I change some things?
what is it going to be used for?
gaming and picture editing maybe some video editing
Everything seems fine, I'd plan on upgrading to the 7850 as soon as possible though seeing how the gtx 500 series is becoming quite dated. As long as you don't plan on doing any overclocking everything seems fine.
Well, your build is really good for gaming :DD
If your really gonna do some video editing like using Adobe Premier, then you're gonna need more RAM.
That's only about it.
thanks for your feedback appreciate it!
