I'm new to this and this will be my first PC build. I took parts from other people's builds on the forums. I just want to know if this will actually work together or if it will bottleneck or something:
http://pcpartpicker.com/user/KuntFloss/saved/2Azh
(If you think one or two components should change feel free to make a modified version).
Additionally from what I understand instead of using a cpu and video card one could just use an APU. (I apologize if I am wrong about this). If this is the case I think one would instead be able to use this and knock almost one hundred US dollars off of the price:
http://www.amazon.com/gp/product/B00CPLGGXM/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B00CPLGGXM&linkCode=as2&tag=teksyndealzon-20
If I am right about the APU I would like to know about the difference between the performance in each build.
