Hello there!
I need your help with solving a network storage dilemma I have since the year began.
All the storage I own (aside from SSD boot drives) consists of 1x12TB, 1x4TB, and 2x1TB 3.5" HDD drives used to be plugged in my old desktop computer. They contain raw video and photo files, music, and mainly many many device backups I have been creating over the years (before phone changes, camera SD dumps after vacations, etc).
Since the structure of them could be considered chaotic (there might be duplicate files, but each backup captures the memories of what I used to do back then, so putting everything uncategorized in the same photo library would ruin the point) I wanted to create a couple of external backups of all the media combined that could be reasonably accessible and long lasting, using optical media.
Then, once that’s done, I would like to set up a easily accesible storage for my home network with the remaining drives so I could access it from both my laptop and other desktops computer. I do not know how secure a NAS would be, but I can imagine the access to it could be restricted to certain visitors foreign devices that say, use the home wi-fi connection from time to time.
The HDDs have been replaced overtime, so at most, the higher capacity ones that hold 90% of the important files are 1.5/2 years old now. When it comes to redundancy, I’m not sure how to set up RAID, every single time I see a video about a real life storage scenario there are problems and when HDDs go wrong it really looks like no fun at all.
All the sensitive files have been put into a secure encrypted container using Veracrypt and a password manager.
So long story short, here are the things I need to solve:
1- When it comes to the optical archive of the full files, do I go for Blu ray storage, M-DISK, tape, or propietary solutions like Sony’s cartridges (which are stacked high capacity disks after all)?
2- Is there any way to easily reorganize the file structure by years while mantaining the timeline? Lets say if I used device A from 2016 to mid 2016 and device B from mid 2016 to early 2017, could some kind of tool sort that out automatically YYYY/mm like Adobe Lightroom does? ( i wont use lightroom to do it since there are more than video photo and audio files in the backups)
3- What solution/ NAS do I go for? I’m overwhelmed with options. The network is 1Gbps or 125MB/s so quick access to the files and backing up should be a problem. Awaiting on 10Gbps upgrade in the next few years.
4- Once the files have been archived safely, I might start cleaning up the NAS disks or deleting the clutter I dont need access to on a daily basis. What are some of the features you like the most about your setup if you use something like this? I’ve seen some video editors from Youtube channels pull some videos directly from servers or network storage to their software timeline, avoiding the hassle of physically connecting external SSDs. Could I do this? If that is true, I guess that could help me run a small form factor PC instead of a full tower right?
5- How secure can I make it? I definitely dont want my storage accessed by non authorized people, I guess it would only be used by the home devices . After I set up my first local network storage, I might look into selfhosting as well, but that is not a priority for me.
Thanks for your help and patience, I hope I didn’t bore you too much
