Need some help picking parts to upgrade
Hey there! Here is my current build: http://pcpartpicker.com/user/HelloImTinyT/saved/7vtNnQ
I just need some help with what parts I should upgrade first and to what I should upgrade to. So far I've thought to just go ahead and upgrade my GPU to a PowerColor Radeon R9 285, but I'm unsure if that would be a good choice. My price range is around $200 for a quick upgrade for the moment, but later on I may end up putting more into it.
Anyway any help would be great and thank you so much!
Might be worth waiting a while for the 300 series of AMD GPUs if you're considering a GPU upgrade.
