Need some extra help/advice for upgrading my rig
So i have a general idea of what to get but i would like some professional/advanced help on what to upgrade and purchase to put in my rig. Also my computer is still running great for what it has but i would like to upgrade for somewhat future proof and more graphically intensive games. My price point is around $500+ depending on most important purchases first like CPU, Mobo, and GPU.
Heres my current build and everything: http://pcpartpicker.com/p/2QJBc
The best way to improve gaming performance would be to change out your graphics card. The 965, while not the best CPU, still does a very decent job for most games, especially those that are more reliant on the GPU, which is most games. It shouldn't bottleneck anything but the most high end cards.
However, if you want to do a complete refresh I would change out the motherboard, CPU and GPU. For a little over $500 you could get this
http://pcpartpicker.com/p/2zo04
An R9 280X would also be a good choice.
Also for an additional $30 you could get an FX-8320 over the FX-6300. Although if you're just gaming it really won't give you that much of a boost.
i would either max out the memory speed, but the most improvement you'll see if a new graphics card. for 500 bucks you have alot of options. too bad AMD cards are so inflated right now.
You do realize memory speed is completely irrelevant on gaming systems systems with a dedicated GPU right? Going from 1600Mhz to 2400Mhz won't change anything. Except make your latency worse. His RAM is fine and changing it would be money wasted.
yeah, im just giving suggestions since it seems he has a hole burning in his pocket. that why i suggested the gfx card update as well. memory seems like the only other thing he can upgrade without changing his platform.
If I recall correctly that cpu can overclock pretty well (at least for most people) so maybe a motherboard and a graphics card would be your best bet. Get a board with better vrms to overclock the processor (so you don't have to buy a new one because it still does pretty good) and then a graphics card which will be the best thing (like was said above) for next gen games.
I had the same parts list picked out basically hahaha. And yeah, the R9 280X is quite nice as well. The 770 or the R9 wont bottleneck my CPU as well right?
Yeah, thanks for the advice. Im going to take a look at a board with better vrms for sure. And I might get the 6300 though for when the 965 takes a shit haha. Running strong for about 2 1/2 years
I would tempted just to get a 290 or a 780 gpu and try it. Win 8 may help some. My two cents. Since your not gonna lose even if your gpu is a little bottlednecked by the cpu. The reason why is say that is that a strong gpu can be carried over into the next build. It would be best to upgrade your entire mobo and cpu for max performance.
A hole burning in my pocket? How so? I know plenty of people that upgrade with newer parts in their rigs than mine haha.
