Mionix naos was $30 on newehh yesterday :(
i'm real happy with my steeleseries sensei
Personally I really like thermaltake mice I really like the coating they use on all of them. Also logitch has well build mice
I use razer (deathadder) but I am thinking about switching to a g600
do you think the older model g500 would be worth it? or should i just go for a different mouse?
Your decision, but are you claw, palm, or fingertip grip?
I am with Nick Fury. For 45 dollars you can get the steel series sensei raw. Its a no nonsense mouse but it is supposed to be a good one. I suppose whether it is worth getting will depend largley on if you are willing to put up with gloss black or not as didnt see the rubberized one on newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826249092
i guess im between claw and palm. I grip the sides of the mouse in a claw form but my fingers kinda lay flat maybe a bit of an arch. But this may be due to the mouse I am currently using, it is just a simple Logitech Wireless mouse used for travel and stuff like that.
Alright, thanks for the input!
