I am interested to get some LED lights and which can go into my 'blue lightning build' I want a 5.25' controller for them too and prefer magnetic led's. I did look at the NZXT ones is there any others that people can recommend ? I want to look at all the options before I get a kit.
Bitfinex sells some magnetic strips that Wendell just mentioned in the latest video on the member build.
Phanteks also sells magnetic led strips...
My only advice is to use white light, otherwise you will drown everything in blue light...
