Need some advice on a Desktop Upgrade
Hello Tek Syndicate,
This is my first post but I'd appreciate some help.
Two years ago I purchased a computer for gaming and over the last 2 years i've been upgrading. My current spec's are
Motherboard: ASUSTeK Computer INC.M4A78LT-M
CPU: AMD Athlon(tm) II X4 640 Processor 3Ghz
RAM: 2x4GB DDR3 Dual Chanel 667Mhz per stick 1.50 V
Graphics: NVIDIA GeForce GTX 560 TI
My upgrade I want is to the CPU and the Motherboard and add some cooling.
I have my eye on THIS CPU
http://www.amazon.co.uk/AMD-FX6300-Edition-4-1GHz-Socket/dp/B009O7YORK/ref=sr_1_1?ie=UTF8&qid=1354135163&sr=8-1
as the clock speed is high, If you think this is a good CPU for overclocking and gaming please can you recormend a motherboard .
OR
Can you recormend me a CPU, Motherboard and Cooling (preferably just a CPU cooler) for a max buget of £300.
Also, My PSU is 850W so can you make sure I won't fry my computer,
Thanks,
Nate
asrock makes good 990fx mobos.... and that's a good cpu..... as far as a cooler goes, frst, do your ram sticks have tall heat spreaders?
I honestly don't know :/ There kinda old ram like 2-3 years old?
i would get a new gpu aswell change it to say  a hd radeon 7850 :) and what make is the psu
and yes that cpu is good :)
