I'm pretty much done with a budget gaming build.All I need to decide is the case ...I would like to get a case that is as silent as possible,without hurting the airflow and getting my system temps up.I have been loking at CoolerMasters Silencio 550...but there is not enough holes and air flow
This is my build.....I need advice on a good case
CPU:FX 6300 Motherboard:Asus M5A99FX PRO R2.0 GPU:Sapphire PCIe 3.0 HD7790 1GB GDDR5 DUAL-X OC
RAM:Kingston 8GB(2x4) 1600MHz DDR3 HyperX 1,35V
HDD:Seagate SATA3 500GB 16MB Barracuda 7200
So I need a case that is as silent as possible,without hurting the airflow and getting the temps up.Also I would like to spend as little as possible on it
