Need recommendations for a budget workstation/gaming build
Hello Tek Syndicate community.  I will soon be in the market for replacing my old and underpowered laptop with a nice up to date desktop.  I am a film student studying stop motion aniamtion and I would like to build a system that will be ablet o handle Adobe production premium CS6 and DragonFrame software.  I am however on somewhat of a tight budget.  I want to keep this build under 1200 bucks, if you guys can do it for under 1000 that's even better, it gives me room to purchase a better camera, extra lighting equipment etc.  So basicaly I need something that is stable, fast and will get the job done.  I will mostly be working in 1080p resolution for my projects, I am not doing any crazy 4k or 2k rendering.  Can you help me tek syndicate?  For great justice?
fx-8350, gtx 660, 16g ram, then whatever looks good for the rest
Could I have some more details than that, will the FX 8350 be able to handle CS6 or should I go for the i5 3570k.  I would also lik to note that I do not plan on overclocking as I am going for good power and stability.
I'd go with the i5 3570K
8350
8350, more cores is good, it can handle CS6 no prob,
hell..When I did freelance work a while back with AE CS5.5 I had an old phenom I x4...which wasn't very smart..but sht it still ran
Try this build I'm planning on doing http://pcpartpicker.com/p/ADRN
I left out the case/cpu cooler/ssd etc, you can pick whatever you prefer
