So I making a new build and I was wondering which one to go with. I do 3D Modelling(ZBrush & Blender), Illustrator, and plan to start playing more PC games. And also I would like to know which build would be able to handle the LG 34UM95-P, which the resolution is 3440x1440.
Please & Thank You.
LGA 2011 Build:
CPU: i7-4930K
GPU: 2 x XFX R9-280 3GB
MOBO: Rampage IV X79 Micro-ATX
PSU: EVGA SuperNOVA 850W
RAM: Vengeance 16GB (4x4GB)
COOLER: Corsair H105
CASE: Obsidian 350D
LGA 1150 Build
CPU: i7-4790K
GPU: EVGA GTX 780 3GB
MOBO: Maximus VII Z97 Micro-ATX
COOLER: Corsair H75
CASE: Silverstone FT03
LGA 2011 build, since having a monitor that large requires some serious gpu horsepower.
Although both would work fine, the 2011 would work better, and if you can afford it, why not :D that's a beastly system, and worlds better than the 1150 setup
I am going to point out that this will heavily come down to CUDA vs openCL for your 3D modelling stuff.
From my research, CUDA has way more support, but I know openCL is getting a lot of momentum as well.
I would probably go with what is going to cut your render time the most. Also.. I am a fan of a single graphics card over crossfire/SLI.
Here are your builds:
First: http://pcpartpicker.com/p/mLCxRB ~$2000
Second: http://pcpartpicker.com/p/qVdkWZ~$1500
Here is a couple tweaked builds:
http://pcpartpicker.com/p/wV3PQ7 ~$1700
- evga superclocked acx 780 ti
http://pcpartpicker.com/p/vRsTpg ~$2000
Both of my builds have quality parts. The difference between the 4930k and the 4970k isnt big enough to spend an additional $400 (CPU and motherboard) when you can put that toward more graphical power. If you want AMD I would put in a r9-290X over 280X crossfire..., but those of these would lose horribly to 780 sli, and a 780 ti is nothing to joke about either.
