Hey guys,
I've just created this system, and I was wondering on what you though of it.
http://uk.pcpartpicker.com/p/PhUG
I want to use this for gaming and just general computer usage.
When it comes to games I will probably be covering a large array of genres from some FPS to RPG and Strategy and also indie games.
I'm not too worried it if can't play everything on ultra setting at a crazy FPS, as long as it's pretty good then I'm happy.
Thanks,
RedRazer
Here's a thread with a similar budget.
Skewt
#3
Get a phenom ii x4 965 be it is worth the extra bux in the long run.
Brann
#4
Agreed with Skewt, the Athon with a 7770 is a bit weak, I would spend the extra cash on the Phenom 965 if you can. Other wise it looks alright.
Yeah, I was wondering if the CPU would just bottleneck the GPU.
That's cool, with the Phenom 965 it equals about £410, including a monitor and everything which os ok with me.
I'll just have to torrent a version of windows.
Cheers guys.
