Need more connectors
so I was thinking about buying another 60 gig ssd and putting that and my current 60 gig ssd (with OS) into a RAID configuration but then I looked and I don't have enough connectors. My corsair cx500m came with 5 sata connectors and I am already using 3 for my various drives and one for my dvd drive and the last one is in a very inconvenient spot. So my question is is there a place where I can get different cables with more connectors or is there a way to convert molex to sata because I have a ton of molex just sitting there. Anyway thanks for the help.
Yes! You can absolutely get them.
http://www.amazon.com/Syba-SY-CAB40007-Molex-Power-Inches/dp/B0027AGK3M/ref=sr_1_sc_2?ie=UTF8&qid=1422982789&sr=8-2-spell&keywords=molex+to+saya
A general rule of thumb is to not split your connectors past the point of your amp draw spec.However, SSDs are really low power so I wouldn't worry about it.
