i need mobo and need your opinion About this build. THANKS! :
http://www.eprice.it/microprocessori-AMD/d-2363345
http://www.eprice.it/hard-disk-eide-sata-SEAGATE/d-4099182
http://www.eprice.it/memorie-PATRIOT/d-4565863
http://www.eprice.it/schede-video-SAPPHIRE/d-4493116(free 2 Games)
http://www.eprice.it/alimentatori-CORSAIR/d-4624367
http://www.eprice.it/sistemi-operativi-MICROSOFT/d-4639688
http://www.eprice.it/masterizzatori-dvd-interni-LG/d-4720768
http://www.eprice.it/case-COOLERMASTER/d-4718471
total 560 euro (mobo not included)
(sorry for bad ENglis) :)
http://www.eprice.it/schede-madri-ASUS/d-4498432
This would be the motherboard I would recommend, I also suggest getting an aftermarket heatsink to replace the stock, I've linked below.
http://www.eprice.it/dissipatori-cpu-COOLERMASTER/d-4138064
thank you .i made some chandes .. graphics card http://www.eprice.it/schede-video-SAPPHIRE/d-4493116
and is 600 watt enough?
600W is overkill ... :)
Using an FX 8320 and HD 7870 with a 500W power supply at the moment. You should get 400W, unless you plan to crossfire.
Woah, 400w? Always run your build through here to check wattage. His build will be pulling about ~440w so 500w would be best.
http://images10.newegg.com/BizIntell/tool/psucalc/index.html
ok..last question .are all the parts listed compatible to eaac other(especially the ram . Graphics card and mobo)? thank you for the help ..really apprciated :)
