Need MOBO help!
http://ca.pcpartpicker.com/p/kkZnMp
Looking for some advice for hardware, specifically the Mobo.
http://ca.pcpartpicker.com/p/KKvLqs
That's the bottom line mobo recommended for an 8-core AMD... I really recommend the Asus M5A99FX PRO R2.0 ... but that's quite a bit pricier in Canada... you'll need aftermarket cooling as well... and while I'm not as big of a fan of the Hyper 212 EVO as everybody else here... it IS a decent cooler, and for the value in Canada I I can recommend it... so that's as cheap as you can go without potential terrible things happening :)
I assume you already storage?
Oh, and I switched the PSU to something that wasn't terrible
Thank you, I greatly appreciate it, and yes I have storage already. :)
