Need links for Ubuntu 10.04
So...after having beta tested a bit of a game on the Windows/Apple platforms, the developers have asked if I'd be willing to see how it runs on Linux. More specifically: "Ubuntu 10.04+/Debian compatible build for Intel processors".
Now the Most I've ever really done with Linux is boot up a free disc from a magazine to see how it was. Beyond that, just my tech tools discs, but none of them required me to know the actual Linux command line or details of configuration. Based off of the build on my profile and the info above, what are your suggestions (about where to go, what I'd need to run basic and stable, NOT commentary on my builds please).
Here: http://releases.ubuntu.com/lucid/
Any particular reason you need 10.04? That's a just about a 4 year old OS, succeeded by 12.04, which is also an LTS release.
UPDATE: Found better link: http://old-releases.ubuntu.com/releases/
+1
Don't install lucid, install precise, that's version 12.04.3 LTS, when it says "10.04+", that means 10.04 or the more recent stable release. 10.04 lucid lynx was an LTS release, the present LTS release is 12.04 precise pangolin, now at it's third iteration 12.04.3, and it's now fully stable and fast. The development releases, unlike the LTS releases, are generally pretty unstable and iffy with Ubuntu, they are more like betas or even alphas in other distros, and they only come out every 6 months, and right now they're at version 13.10, which is a pretty fast version (although not as fast as 12.04.3), but oh so buggy (but new users probably wouldn't even notice the bugginess because coming from Windows or OSX, it has very few annoying bugs in comparison). The next release will be 14.04 LTS, which will again be the "official" Ubuntu version for two years.
So 12.04.3 LTS is the version of Ubuntu you should install now.
if I understand correctly you need Ubuntu 10.04 or newer/ or whatever version of debian that corresponds to or newer
I believe that most distros come fully pre-configured, not that you couldn't optimize them but it's not necessary, the most you should have to manually configure would be the partition setup when going through the installer, I've been going with 256MB on the /boot partition to be generous and whatever space you want the file system to have goes on the / partition, the formatting is usually ext4 by default not that you couldn't use something else
this gives quite a lot of options as debian has a fairly large amount of variants, but i'll just start listing off some of the ones that I can think of/like
  • Ubuntu based on debian
  • debian the father of whatever you end up using (i'm not sure this is the best link, but i'm having issues finding a clear cut "here's the amd64 .iso")
  • Linux mint based on Ubuntu 13.10
  • Linux mint debian based on debian, rolling release (will update as updates become available as opposed to waiting for the next fixed release)
  • elementaryOS based on Ubuntu 12.04
I recommend doing a bit of your own research to pick one, maybe mess around with them in a virtual machine, realistically they're all about the same for usability, will use *roughly* identical terminal commands, so let's say you need help with mint, you can follow a tutorial that was designed for Ubuntu or debian
http://cdimage.debian.org/debian-cd/current-live/amd64/iso-hybrid/ Live cd/dvd diwnloads of Debian.
 http://www.ubuntu.com/download/desktop
I had a follow-up discussion and the current variants will be fine for their testing purposes. Now I just have to sort out installing the actual OS as I'm sure it's moderately different than the Win/OSX types. Having not downloaded anything yet, are there any quirks/steps I might need to look out for? Does it start off with a partitioning manager? Is having two Other OS drives on the same system going to play hell with the Linux boot manager?
With Ubuntu, most everything is automated in the installation process. You set up your account, time zone, and language/keyboard layout, and that's more or less it. When it comes to partitioning, you do have the option to manually partition your disk (called "something else"), but there are preset options. The Ubuntu installer will detect most any OS already installed and give you options depending on what it finds: Install along side [other OS], Upgrade [Ubuntu x] to [Ubuntu Y], erase disk/install Ubuntu, or something else, which fires up a partition manager. In all cases, Ubuntu will install and auto-configure GRUB, the boot-manager, so if does detect other OSes, you can dual/multi-boot.
But will Grub interfere with the "Windows Boot Manager" taking boot priority? They'd be on completely different drives so I see it being less of an issue, but then again...
GRUB will boot most anything under the sun (including Windows), so it won't interfere with the operation of Windows. Windows Boot Manager will only boot Windows. So the only bootloader that interferes with your computer's operation is the Windows Bootloader. I don't see an issue if/when GRUB overwrites Windows Bootloader. I've been dual-booting since Ubuntu 8.04 (2008). However, if you re-install Windows, Windows will overwrite GRUB; in that case, you will have to live boot Linux and re-install GRUB if you want to boot your Linux OSes.
If you install the boot manager on two seperate drives, the boot loader that takes priority will be whichever hard drive you have first in your boot order. I recommend GRUB as first, as it can boot anything, although I haven't personally tried booting an OS on a seperate drive from GRUB, though I suspect GRUB will detect Windows on the other drive (provided it's a permanent drive), and give you the option to boot it up.
ok, so the bootloader only affects the drive it's being installed to then. so if they're installed on separate drives, then realistically, If I didn't want them to interact (IE: I want Win as default and only want to load Linux manually), then I just simply make sure that the Win bootloader is set in uefi and do my normal F12 to boot from other drive (like for CDs, USB, etc) like I do for my OSX installations. This probably isn't a permanent thing, so didn't want to change the existing setup.
