Hey everyone, I have an RX 550 as a host on Ubuntu 17.04 with a GTX 1070 as the guest GPU for Windows 10.
I have a Asus Sabertooth X79 MOBO and i7 4930k, which has vt-d support.
I have intel_iommu=on set in grub.
My GTX 1070 is set to use pci-stub as it's drivers.
In the Asus BIOS, 'Intel Virtualization Technology' is enabled, BIOS is up to date.
When I run dmesg | grep -e DMAR -e IOMMU
result:
[ 0.000000] DMAR: IOMMU enabled
[ 1.343259] AMD IOMMUv2 driver by Joerg Roedel [email protected]
[ 1.343259] AMD IOMMUv2 functionality not available on this system
Yet when I start the installation on virt-manager, I get this error as seen in screenshot.
Not sure what I'm missing here, any thoughts would be great. Thanks.
Here's the error under details.
Traceback (most recent call last):
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 90, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/create.py", line 2277, in doasync_install
guest.start_install(meter=meter)
File "/usr/share/virt-manager/virtinst/guest.py", line 501, in start_install
noboot)
File "/usr/share/virt-manager/virtinst/guest.py", line 416, in createguest
dom = self.conn.createLinux(start_xml or final_xml, 0)
File "/usr/lib/python2.7/dist-packages/libvirt.py", line 3491, in createLinux
if ret is None:raise libvirtError('virDomainCreateLinux() failed', conn=self)
libvirtError: unsupported configuration: host doesn't support passthrough of host PCI devices
