Need inspirations on build and and a monitor to go with it
Hello and a good day.
I have a budget of 930€ wich was actually just for the Pc, but I needed to drop that idea when I realised I had to  get a monitor after all.
So now I have about 950 € to spend on a Pc and a monitor. I would like to get some advice on components from you.
Pc: It is going to be a gaming rig in first place, but it must not be just for gaming because I want to do a bit of editing and photo work on it. I would like to have it quiet.
I´m pretty set on the case ( Phanteks Enthoo Pro, black w/ window) and I don´t think there will be more CPU in it than the FX 8350, but if there are better options for both will gladly take them. So I would , of course, like to get a GTX 970.
That are some of the parts that came to mind. I have already some ideas but I would like to see some ideas of yours.
Monitor: That I think is the tricky part. I don´t want a cheap monitor because I would like to try something new ( I´ve been using an old 5:4 monitor with terrible colour).
I would love to try 1440p or a 21:9 monitor, but if necessary I would take a 1080p TN or IPS panel.
I hope it isn´t too tricky and I look forward to your suggestions.
Have a nice day.
That case looks nice. 970 is good. I'd go with Intel. i5 for this budget? It just seems to work better in games.
IPS is a must I think, make sure it has a good response time.
Thank you very much for the fast response. I like the idea of the i5 but I also would love to try some overclocking so I have to look if I can get a "K" part in it :D . Well i´ll think about it.
I would like to habe some concrete suggestions, if it is possible. I don't really know what combination I can fit in the budget.
happy to pick parts. I couldn't find the case you wanted in €. http://de.pcpartpicker.com/p/k9X3jX
Monitor, for the budget its hard, maybe:
http://www.amazon.de/LG-24EB23PM-B-LED-Monitor-Reaktionszeit-schwarz/dp/B00B4GNXYO/
Thank you very much. I think I can fit in a cooler. Thermalright hr-02 macho or coolermaster hyper 212, wich one us better?
Thermalright. But you're not going to use it cuz its not a K cpu and Z97 mobo. limited by budget, though 4460 is all you need for gaming.
I know but I don't like the stock heat sink.
This would be a fairly well-rounded system IMHO: http://de.pcpartpicker.com/p/m6zCqs
If nothing else that monitor looks like it would fit your needs and budget quite well.
Based on the prices I've seen combined with personal experience, I tend to recommend to anyone on a budget - the Dell 2340M 23" IPS panel. Looks amazing and is usually around $150 US - But the Acer equivalent model is also exceptional - and I found one at 24" cheaper than the 23" versions I have used before. Here is the link - http://www.amazon.de/Acer-S242HLCBID-Monitor-Reaktionszeit-schwarz/dp/B005PLFAH2/ref=pd_cp_computers_1
My thanks. It looks good but I need a bit more CPU power. So I've thought it through and I think I don't really need the 970 for 1080p. I think the AMD r9 280x will do just fine at first.
so this is an idea I had. It is 100€ more expensive than where I would buy it. http://de.pcpartpicker.com/p/hymWjX
