So one side of my IEM broke and I need a new pair ASAP. I was wondering if best buy is a good place to look for one. I’ve never really shopped at best buy and that’s the only tech store that I can access right now.
What's your price range?
For $10-$30, you can pick up some of the philips SHE3590BK series for about $10. They aren't great, but they deliver, in my opinion, better quality than the apple ones.
I was just wondering about shopping for IEMS at best buy in general. Do they have a good swlection and are they overpriced? I don't have a budget yet but I guess $10-$20 sounds about right.
Check out this SKU: SHE3590BK
You can find them at Target, not sure about Best Buy.
If you need something quick, these are probably your best bet to hold you over until you can get a higher quality IEM.
To answer your question, they don't have a great selection for people who care about quality, because most people just take what they see on the shelf. (more money means better product mentality)
That said, their prices aren't awful (still not great though) when you're looking at the low-end stuff. If you want to spend more than $50 on a pair, that's when they start getting overpriced.
That's about as far as my expertise goes in this category. Wish I could help more.
Thanks for your input!
"GASP" That sounds horrible! Best Buy that is really sad.
