Need Ideas of Cooling my CPU
Hey guys,
I'm looking for a decent cooler for my CPU, passive or watercooling. I was thinking about an h100i or something but I'm not sure if it will fit in my case. Give me some ideas please!
System:
  • Amd a10-5800k
  • Patriot Viper 3 8gb @ 1866mhz
  • Thermaltake Commander MS-I (Snow Edition)
  • GTX 560 ti
  • Gigabyte Ga-f2a85x-up4
Well look around see if someone fitted it in your case, else just get a H80i or a performance air cooler
TheThermaltake Commander has support for 2 top 120s with correct spacing to support a 240 rad like the h100i it also has a 8" width so it should support most of the large air coolers like the noctuas and hyper 212 as long as your mobo layout doesent cause the fans to obstruct the memory slots as is sometimes the case.
I have the Noctua NH-U9B SE2, with 92mm fans, it perfoms as hell! I have mi i5 3570k at 4.7 Ghz with 1.370v, and it stays lower than 85c.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608016
