Need help!
what does it mean to overclock???
Overclocking is increasing the frequency at which a chip operates to yield more performance by gaining more flops per time unit.
In a very basic sence it means to increase the rate at which a processor performs tasks.
Usually this means to increase the clock cycles.  This will usually mean increasing the voltage to the processor and the by-product of this is more heat output.
It's an advanced method of time travel, you'll get used to it. Good luck in your travels broham!
lol
