Need Help
Hi Iam looking for a mini pcie wifi card with antennas to go with my evga z77 stinger mini itxmotherboard please do not recommend the asus p8z77 I deluxe or the gigabyte z77n wifi, due to I need the evga support 2133mhz ram.
sam
Here is what i found. http://www.newegg.com/Product/Product.aspx?Item=N82E16833106165 and then need to get https://www.sparkfun.com/products/662 and https://www.sparkfun.com/products/558. Not sure if this is what you're looking for.
Thanks
Np let me know how it works. :)
