Need help with wiican
(wiican:21241): GConf-WARNING **: haven't implemented getting a specific locale in GConfClient
ERROR:dbus.proxies:Introspect error on :1.16:/org/gnome/Wiican: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Traceback (most recent call last):
  File "/usr/local/bin/wiican", line 386, in <module>
    launch_indicator()
  File "/usr/local/bin/wiican", line 345, in launch_indicator
    wiican = WiicanIndicator()
  File "/usr/local/bin/wiican", line 139, in __init__
    self.__cur_status = self.__wiican_iface.GetStatus()
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name :1.16 was not provided by any .
So I just recently got back into emulation, and the memories of the finger cramps from playing mario on a keyboard are back, but this time I come with a defense, a wiimote. A wiimote is the closest thing I have to a gamepad, and I saw that you can hook them up as a HID device, so I see this as I prime opportunity to reduce long term carpel tunnel. My problem and the python logs come into play now, as I was to lazy to imput the commands for mapping the buttons to my desired keys in xf86-xinput-xwiimote or just make a bash script, I saw something that was already compiled in a PPA, wiican. Only problem is that the PPA doesn't have a amd64 package, so I needed to make it from the tar ball. Now when I installed all the dependancies (I think) and ran the setup script and went to click on it, nothing happened, so I went to the command line and ran it and this is the output. Now I am not super used to GTK and Python, so if anyone can give me some insight outside of the scope of my lamen's perspective that would be great.
How to fix wiican, use dolphin instead.
Wait, dolphin allows for wiimote keyboard emulation? I just need it as an input device, dolphin allows for this?
I just need the wii remote as a HID device, as a gamepad for Zsnes and to act as a remote for netflix
