kosh
October 11, 2013, 8:21am
#1
Hi, I just wanted to find out a few things about my upcoming water cooled build.
I want to get the NZXT Switch 810 Case in black and wanted to know if I can fit these components in it -WITHOUT MODDING-
1x XSPC EX 420 Radiator for the Top which is 143 x 36 x 460 mm (WxDxH)
1x XSPC EX 280 Radiator for the Bottom which is 143 x 36 x 320 mm (WxDxH)
1x XSPC X20 DC-750 - Dual 5.25" Bay Reservoir/Pump Combo which is 149 x 100 x 85mm (WxDxH)
Please Let Me Know Soon.
Thanks.
deejeta
October 11, 2013, 9:22am
#2
Top rad fine, bottom rad - unless you have a really, really long psu this will be fine as well. You can definitely go for thicker rads cause you have more than enough room, nothing wrong though with the ex rads I guess.
Hope it all works out for ya.
kosh
October 13, 2013, 12:53am
#3
Thanks heaps for your help, I might just get a double 120mm extra thick rad for the bottom since the psu is kinda long
deejeta
October 13, 2013, 2:49am
#4
I have the RX240 in the bottom of my switch 810, even in push/pull there is room to spare.
