I'm not very knowledgeable about PC's in terms of specific speeds and terms especially with GPU's but I understand how they are put together and what each part does, so please bear with me if I say something incorrectly.
I've been using iBuyPower's website to figure out a build, I feel that I'm putting together something that isn't gonna satisfy the bang for buck. I usually play on my laptop that's hitting about 4 years now, and I need a nice PC. I do want to include a monitor within the budget as well as a keyboard and decent gaming mouse.
I don't want to build the PC myself, I could put it together but I think the BIOS portion is gonna freak me out. So that's why I headed on with iBuyPower's website. If you can recommend a better solution like with newegg website (I don't know if they build the PC then ship it like iBP's), any suggestions would be appreciated. I say 2100 budget because that's about the absolute limit, however I'm buying a couple games listed at the bottom of this post, so I want about a $200-300 buffer which means I have 1800-1900 left for the PC. If you can suggest something below that would be awesome.
Current iBuyPower build ($1730 grand total including shipping)
NZXT Source 210 Mid Tower Case Red
AMD FX-8350 CPU (8x 4.00GHz/8MB L3 Cache)
Asetek 510LC Liquid CPU Cooling System
8 GB [4 GB x2] DDR3-1600 Memory Module
AMD Radeon R9 FURY X - 4GB
MSI 970A-G43 -- AMD 970 w/ 2x PCI-E 2.0 x16, 2x USB 3.0
PSU: 600 Watt - Standard 80 PLUS Bronze
1 TB Western Digital Caviar Blue Hard Drive -- 64MB Cache, 7200RPM, 6.0Gb/s
24x Dual Format/Double Layer DVD±R/±RW
Windows 10 Home ($60)
iBUYPOWER Standard Gaming Keyboard (FREE from iBP)
iBUYPOWER Standard Gaming Mouse (FREE from iBP)
iBUYPOWER High Performance Gaming Mouse Pad ($9)
22" [1920 x 1080] Sceptre E225W-1920 LED Monitor ($139)
OTHER NOTES----------------------------------------------------------------------------------------------------------------------
So I want a machine to game on, that's what it revolves around to but I will be doing a bit of work with Blender and Unreal Engine and maybe some more modelling/render related programs so I may need a hefty GPU (I don't want a workstation GPU, I even thought about leaping for a Firepro). I did consider slapping on a whopping Titan X and that got me up to 2225 grand total. I'm still considering it but if the R9 Fury X can run the games I listed below at fps above 40 preferably as close to 60, then Titan X probably out of the equation. I do want a machine that can handle anything, if not; handle a lot of things graphics related. My build is completely flexible for you just make sure you include:
-PC tower/desktop.
-Monitor (NOT 4K, 1080p is just fine) w/ keyboard and mouse.
-Runs above 40fps but would like it to get as close to 60 as possible
-$200-300 of Steam/Origin credits to buy games.
-Make sure the PC has wireless connection for internet.
-If using a website like iBuyPower, make sure they can build it and ship it to me.
-Grand total (including 200-300 for games) is less than or equal to $2100 (if more, than I may have some exceptions).
WISHLIST GAMES:
The Forest - $15
CS:GO - $15
DBZ XU- $50
Mad Max- $60
Shadow of Mordor - $50
GTA V - $60
Watch Dogs - $40
Battlefield Hardline (via ORIGIN) - $30
Need for Speed Rivals (via ORIGIN) - $10-20
The Witcher 3 -$60
