Need help with something i've been wondering
So I want to upgrade a few things for my rig like my motherboard, graphics card, cpu, and thats about it, and i was wondering when i get those new upgraded parts into my rig, can i just connect my harddrive with my OS on it and just boot up like normal or is there something else i have to do?
Probably not... It all depends on your hardware. I was able to move from Z77 to Z87 without issues, but if you  are moving to something very different from the original it might be weird. Also, there might be lingering issues, driver remnants, etc.
It can be done (sometimes), but I would really, really recommend doing a clean install.
+1 (ofc, its logan)
With such a large pc upgrade, I'd usually recommend a clean install to prevent any driver conflicts.
Alright, thanks so much for the advice Logan. I'll definitely do a clean install. Im moving my 890FX to a 990FX so i'm sure i'd need to haha. By the way, had to add, I love the Tek and your content, keep up the good work man.
