Need help with SLI
I have a 660 ti FTW signature 2 edition and I was wondering if I could sli it with a regular 660 ti from ASUS or GIGABYTE. I would by the same card again but it has been discontinued.
Thanks
If it has the same amount of ram then it should be ok, but I'm not sure.
it has to be the same GPU and RAM. You got the first part right, not sure about the second.
I looked it up on newegg and its discontinued but i havent looked elsewhere.
Yup, so long as it is a 660 Ti with 2GB of VRAM, you shouldn't have any trouble.  Just make sure there's enough room in your case.  And make sure your motherboard and PSU can support the second card.
