I have a Supermicro X9DR3-i/F running the latest BIOS with two Intel Xeon E5-2667 v2. The server is freezing but not restarting or shutting down. This seemed to only happen when the server had been on for about a month. I thought it was just OS instability, but today it happened again after only being up for four days. I investigated the IPMI event log and its showing “CPLD CATERR – Asserted”. Any ideas on what is causing this? I noticed in the IPMI after the error all the RAM slots were showing as not present in the sensor list, I am running a mem test now.
Memtest finished, no errors reported.
Possibly a ram error but may be cause d by connection the to CPU
Try reseating the CPUs first. If that doesn’t work you will need to eliminate one component at a time, namely drop to one CPU, half the ram, see what happens. If you workload can’t support a month of testing doing that then it is time for an upgrade.
I reseated the CPU’s and RAM, now we wait.
I think the CPU reseating may have fixed the issue. The server has been up for 51 days now, however I upgraded the hypervisor and did not re-enable IOMMU so next reboot I will enable that.
Congratulations. I suggest you mark the thread as solved so others can learn from your experience.
Good luck with the new setup.
