No problem!
I would suggest that you look into Debian (without a graphical interface) for your VMs, as that is what you would end up using on a server.
I would also recommend that you look into Nginx. It's much faster for static content and allows you to use HHVM for PHP (also really fast). If you plan to continue into the realm of PHP, then definitely go for Nginx and HHVM at the beginning. Also, choose a real framework for advanced projects (don't waste your time managing your requires and database functions). I like Laravel. Also, always remember that MySQL is not the only option. There are countless alternatives. I've had good luck with both PostgreSQL and MariaDB. The problem with most PHP tutorials is that they lock you in on the LAMP/XAMP stack. Don't become narrow-minded like I did.
Good luck and have fun!
