So it is puking because it is trying to use a init script and Arch now has SystemD rather then init scripts. Arch does not have an init.d directory for backward compatibility with old programs.
Theoretically, you should be able to build it manually just fine, then modprobe the module to use it.
install.sh
#!/bin/bash
if test $(id -u) != “0”; then
echo "Please supply root’s password to install this package. "
su -c “$0”
ret=$?
exit $ret
fi
pidfile=/var/run/yum.pid
export DEBIAN_FRONTEND=noninteractive
checkyum()
if test -f “$pidfile”; then
if test “$1” = “check”; then
echo “YUM is being used: enter ‘q’ to exit the kernel-devel list.”
else
echo “YUM is being used: enter ‘q’ to exit the $1 installation.”
fi
while test -f “$pidfile”; do
echo -n .
read -t 1 c
if test “${c}” = “q”; then
exit 1
fi
done
echo
fi
installpkgcentos()
if ! type $1 >/dev/null 2>&1; then
if ! rpm -qe --quiet $1; then
echo “Installing required package: $1”
checkyum $1
yum -y --quiet install ${1} >/dev/null 2>&1
if test $? != 0; then
echo “Failed to install package $1.”
return 1
fi
fi
fi
return 0
checkapt()
lockfile=/var/lib/dpkg/lock
if test -f “$lockfile”; then
if lsof “$lockfile” >/dev/null 2>&1 ;then
echo “APT is being used: enter ‘q’ to exit the linux-headers list.”
else
echo “APT is being used: enter ‘q’ to exit the $1 installation.”
fi
fi
while lsof “$lockfile” >/dev/null 2>&1; do
echo -n .
read -t 1 c
return 1
fi
done
fi
return 0
installpkgdebian()
checkapt $1
apt-get -y -qq install ${1} #>/dev/null 2>&1
return 1
fi
fi
return 0
checkpkg()
if ! type $1 > /dev/null 2>&1; then
return 1
else
return 0
fi
downloadinstall()
name=$(basename “$1”)
baseurl=$(dirname “$1”)
rm -f /var/tmp/${name}
if type curl > /dev/null 2>&1; then
if curl --connect-timeout 10 -s “${baseurl}/” 2>&1 | grep -s -q “${name}”; then
echo “Downloading package ${name} from ${baseurl}.”
curl --connect-timeout 10 -s -o /var/tmp/${name} “${baseurl}/${name}”
if test $? = 0; then
echo “Installing package ${name} from downloader.”
checkyum kernel-devel
yum -y --quiet localinstall /var/tmp/${name} >/dev/null 2>&1
return 0
fi
fi
fi
return 1
installkerneldcentos()
cdroms=$(ls /dev/sr* 2>/dev/null)
if test “${cdroms}” != “”; then
for i in ${cdroms}; do
mkdir -p /var/tmp/cdrom
if test -e $i; then
mount $i /var/tmp/cdrom > /dev/null 2>&1
if test $? != “0”; then
rmdir /var/tmp/cdrom
continue
fi
if test -f /var/tmp/cdrom/.discinfo; then
break
else
umount /var/tmp/cdrom
fi
fi
done
fi
#if ! test -d /var/tmp/cdrom; then
echo “Installation media was not found.”
#fi
kernels=$(rpm -qa kernel)
if test “$kernels” = “”; then
return 0
fi
kernelds=$(rpm -qa kernel-devel)
checkyum check
reps=$(yum --quiet --showduplicates list kernel-devel 2>/dev/null | grep ^Avail -A 100 | grep kernel-devel)
for kernel in ${kernels}; do
kerneld=${kernel/kernel/kernel-devel}
if echo “${kernelds}” | grep -s -q ^${kerneld}$; then
continue
fi
pkgversion=${kernel/kernel-}
pkgversion=$(echo ${pkgversion} | rev | cut -d. -f2- | rev)
inreps=0
if test "$pkgversion" != ""; then
if echo "${reps}" | grep -s -q "${pkgversion}"; then
inreps=1
fi
fi
if test -f /var/tmp/cdrom/Packages/${kerneld}.rpm; then
yum -y --quiet localinstall /var/tmp/cdrom/Packages/${kerneld}.rpm >/dev/null 2>&1
echo "Failed to install package ${kerneld}.rpm."
fi
elif test "$inreps" = "1"; then
echo "Installing package ${kerneld}.rpm from yum repository."
yum -y --quiet install ${kerneld} >/dev/null 2>&1
fi
elif test -e /etc/centos-release; then
if echo ${pkgversion} | grep -s -q 2\\.6\\.32; then
maj=6
rev=$(echo ${pkgversion} | cut -d- -f2 | cut -d. -f1)
dir=Packages
if echo ${kerneld} | grep -s -q x86_64; then
arch=x86_64
else
arch=i386
fi
case "${rev}" in
71)
dir=RPMS
min=0
131)
min=1
220)
min=2
279)
min=3
358)
min=4
431)
min=5
min=""
esac
if test "${min}" = ""; then
continue
fi
if test "${min}" -gt 3; then
downloadinstall http://mirrors.kernel.org/centos/${maj}.${min}/os/${arch}/${dir}/${kerneld}.rpm
continue
fi
downloadinstall http://mirrors.kernel.org/centos/${maj}.${min}/updates/${arch}/${dir}/${kerneld}.rpm
continue
fi
fi
downloadinstall http://mirror.symnds.com/distributions/CentOS-vault/${maj}.${min}/os/${arch}/${dir}/${kerneld}.rpm
continue
fi
downloadinstall http://mirror.symnds.com/distributions/CentOS-vault/${maj}.${min}/updates/${arch}/${dir}/${kerneld}.rpm
continue
fi
downloadinstall http://vault.centos.org/${maj}.${min}/os/${arch}/${dir}/${kerneld}.rpm
continue
fi
downloadinstall http://vault.centos.org/${maj}.${min}/updates/${arch}/${dir}/${kerneld}.rpm
continue
else
echo "Failed to download or install package ${kerneld}.rpm."
fi
fi
continue
fi
done
if test -d /var/tmp/cdrom; then
fi
installkernelddebian()
for i in /boot/vmlinuz-*; do
#dpkg -S $i 2>/dev/null | cut -d: -f1
pkg=dpkg -S $i 2>/dev/null | cut -d: -f1
if test “$pkg” != “”; then
#pkg=echo $pkg
#pkg=echo $pkg
pkgd=${pkg/image/headers}
checkapt $pkgd
echo “Installing package ${pkgd} from APT repository.”
apt-get -y -qq install $pkgd
fi
done
#MODNAME=grep TARGETNAME product/*/linux/Makefile | sed s'# ##'g | cut -d\= -f2 | sed s'#\r##'
echo “Starting install R750 Linux Open Source package …”
MODNAME=r750
if test “$NOCOMPINSTALL” = “”; then
if test -e /etc/redhat-release; then
installpkgcentos gcc
checkpkg gcc
echo “Package gcc not installed and failed to install. exiting …”
exit 1
fi
installpkgcentos make
checkpkg make
echo "Package make not installed and failed to install. exiting ..."
exit 1
fi
installpkgcentos perl
checkpkg perl
echo "Package perl not installed and failed to install. exiting ..."
exit 1
fi
elif test -e /etc/debian_version; then
installpkgdebian gcc
checkpkg gcc
exit 1
fi
installpkgdebian make
checkpkg make
exit 1
fi
installpkgdebian perl
checkpkg perl
exit 1
fi
else
echo “Current running system is not a CentOS 6/Debian system.”
echo -n "Do you want to continue the installation? (y/n): "
read ans
if test “$ans” != “y”; then
exit 1
fi
checkpkg gcc
echo "Package gcc not installed. exiting ..."
exit 1
fi
checkpkg make
echo "Package make not installed. exiting ..."
exit 1
fi
checkpkg perl
echo "Package perl not installed. exiting ..."
exit 1
fi
fi
fi
if [ “$MODNAME” == “” ]; then
echo “Could not determine driver name”
fi
rm -rf product//linux/.ko
rm -rf product/*/linux/.build
rm -rf /usr/share/hptdrv/$MODNAME
mkdir -p /usr/share/hptdrv/
cp -R pwd
rm -f /usr/share/hptdrv/$MODNAME/install.sh
rm -rf /usr/share/hptdrv/$MODNAME/dist
chown -R 0:0 /usr/share/hptdrv/$MODNAME
#touch /etc/sysconfig/hptdrv || exit 1
#echo MODLIST="$MODNAME" > /etc/sysconfig/hptdrv
if test -d /etc/rc.d/init.d; then
rm -f /etc/rc.d/init.d/hptdrv-monitor
install -m 755 -o root -g root dist/hptdrv-monitor /etc/rc.d/init.d/
rm -f /etc/rc.d/init.d/hptmod
install -m 755 -o root -g root dist/hptmod /etc/rc.d/init.d/
str_sed=sed -n '/Required-Start:.*hptmod/p' /etc/rc.d/init.d/udev
if test “$str_sed” = “” ;then
sed -i ‘/Required-Start:/s/.*/&hptmod/’ /etc/rc.d/init.d/udev
fi
fi
elif test -d /etc/init.d; then
rm -f /etc/init.d/hptdrv-monitor
install -m 755 -o root -g root dist/hptdrv-monitor /etc/init.d/
rm -f /etc/init.d/hptmod
install -m 755 -o root -g root dist/hptmod /etc/init.d/
str_sed=sed -n '/Required-Start:.*hptmod/p' /etc/init.d/udev
sed -i ‘/Required-Start:/s/.*/&hptmod/’ /etc/init.d/udev
fi
fi
fi
install -m 755 -o root -g root dist/hptdrv-rebuild /usr/sbin/
if test -d /var/lock/subsys; then
touch /var/lock/subsys/hptdrv-monitor
fi
if type update-rc.d >/dev/null 2>&1; then
update-rc.d -f hptdrv-monitor remove >/dev/null 2>&1
update-rc.d hptdrv-monitor defaults >/dev/null 2>&1
update-rc.d -f hptmod remove >/dev/null 2>&1
if test -s /etc/init.d/.depend.boot; then
update-rc.d hptmod defaults >/dev/null 2>&1
update-rc.d hptmod enable S >/dev/null 2>&1
else
# start it before udev
update-rc.d hptmod start 03 S . >/dev/null 2>&1
fi
fi
else
if test -d /etc/rc.d/rc0.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc0.d/K10hptdrv-monitor
fi
if test -d /etc/rc.d/rc6.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc6.d/K10hptdrv-monitor
fi
if test -d /etc/rc.d/rc1.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc1.d/S10hptdrv-monitor
fi
if test -d /etc/rc.d/rc2.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc2.d/S10hptdrv-monitor
fi
if test -d /etc/rc.d/rc3.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc3.d/S10hptdrv-monitor
fi
if test -d /etc/rc.d/rc4.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc4.d/S10hptdrv-monitor
fi
if test -d /etc/rc.d/rc5.d; then
ln -sf …/init.d/hptdrv-monitor /etc/rc.d/rc5.d/S10hptdrv-monitor
fi
fi
OS=
[ -f /etc/lsb-release ] && OS=sed -n '/DISTRIB_ID/p' /etc/lsb-release | cut -d'=' -f2 | tr [[:upper:]] [[:lower:]]
if [ “${OS}” = “ubuntu” ] ;then
type upstart-udev-bridge > /dev/null 2>&1
if [ “$?” = 0 ] ;then
install -m 755 -o root -g root dist/hptdrv.conf /etc/init/
install -m 755 -o root -g root dist/udev.override /etc/init/
fi
fi
if type systemctl >/dev/null 2>&1; then
rm -f /lib/systemd/system/systemd-hptdrv.service
rm -f /usr/lib/systemd/system/systemd-hptdrv.service
if test -d /lib/systemd/system; then
install -m 644 -o root -g root dist/systemd-hptdrv.service /lib/systemd/system/
install -m 644 -o root -g root dist/hptdrv-monitor.service /lib/systemd/system/
elif test -d /usr/lib/systemd/system; then
# suse 13.1 bug
if test -f “/usr/lib/systemd/system/[email protected]”; then
mkdir -p “/usr/lib/systemd/system/[email protected]/”
install -m 644 -o root -g root dist/50-before-network-online.conf “/usr/lib/systemd/system/[email protected]/”
fi
install -m 644 -o root -g root dist/hptdrv-monitor.service /usr/lib/systemd/system/
install -m 644 -o root -g root dist/systemd-hptdrv.service /usr/lib/systemd/system/
fi
systemctl daemon-reload >/dev/null 2>&1
systemctl enable hptdrv-monitor.service >/dev/null 2>&1
systemctl enable systemd-hptdrv >/dev/null 2>&1
systemctl start hptdrv-monitor.service >/dev/null 2>&1
fi
if [ -d /etc/initramfs-tools/scripts/init-top ]; then
install -m 755 -o root -g root dist/hptdrv /etc/initramfs-tools/scripts/init-top/
fi
#if [ -d /etc/initramfs-tools/conf.d ];then
file_p=/etc/initramfs-tools/conf.d/driver-policy
conf=""
if [ -f ${file_p} ] ;then
conf=sed -n '/^MODULES=[a-z]*/p' ${file_p}
fi
if [ “${conf}” = “” ] ;then
echo MODULES=dep >> ${file_p}
else
sed -i ‘s/^MODULES=[a-z]*/MODULES=dep/’ ${file_p}
fi
#fi
#if [ -d /etc/dracut.conf.d ]; then
echo “omit_drivers+=$MODNAME” > /etc/dracut.conf.d/${MODNAME}.conf
#fi
echo “Checking and building device driver for R750…”
env MODINSTALL=1 /etc/init.d/hptdrv-monitor start
env modules="${MODNAME}" /etc/init.d/hptdrv-monitor force-stop
echo “Driver r750 for some kernel built failed, please refer to file /var/log/hptdrv.log”
fi
fi
vim: expandtab ts=2 sw=2 ai
