Ok so my new pc is finally working, and Im not quite sure where I should have put this question so I'll just put it here. When I go into windows 7 control panel my resolution is at 1360X768 and it fits my tv perfectly, but when I put it to 1920X1080 it becomes all grainy and the whole screen doesnt fit, the tv does support 1080p, whats going on?
Btw, im using a hdmi cable if it even matters(i know i should switch to vga)
Ok when I play ps3 in the top left my tv tells me what resolution im playing on, which is 1080p. Now when I go on the samsung website they show they display 1366X768. Im not sure if my tv is this one as it is now 2 years old. anyways it was a 32 inch samsung 4 series
If the website says that the default is 1366x768, thats what its going to run best at. If you try to run 1920x1080 on a 1366x768 monitor, you are only going to see 1355x768. In simpler terms, you are not seeing 554x314 pixles which is why the display is bigger. Just run it at 1366x768 and you will get the entire picture on the screen even it isnt full screen.
