Need help with Punkbuster
I just bought Battlefield Bad Company 2 yesterday during the Steam Summer Sale. I unwittingly played 3 hours on a non-Punkbuster server, and thought everything was fine. It wasn't. As soon as I joined a ranked, PB server, I can play for around a minute or so before being kicked with the error "Corrupted file/memory [85000]" I've scoured the internet, trawled through countless different forums, and found only the advice to reinstall PB, which I've done multiple times. I submitted a support ticket to evenbalance and I'm hoping to hear back, but I was wondering if anyone here could help. >_> Any assistance rendered would be much appreciated.
in stream you can right click the game and go under the tab that allows you to verify the game files if it finds somthing wrong it will fix it usually.
Tried that already, did it again at your suggestion and nothing changed. 2 files failed to verify and were reaqcuired, but apparently those files weren't the source of the problem.
Anyone else have suggestions?
I've had problems with Punkbuster from day one. The only relief I got was to find it and remove it entirely, then install Punkbuster from their website. After a couple tries of doing this I finally got it to work.
