Hi, I’m trying to find some assistance in getting my gpu passthrough setup to run windows in a virtual machine inside fedora 26. Everything I’ve read about my hardware says it all should be compatible but I continue to run into an issue. Prior to making any changes to my configuration; I cannot get any display from my igpu ports. The monitor plugged into my igpu has no signal. If I disconnect my nvidia card from my mobo and reboot “only” using my igpu; everything works fine…
After using pci-stub to prevent fedora from grabbing my nvidia card (with one monitor plugged into the nvidia and one into the igpu) *not sure if it matters but from within bios I also have integrated gpu enabled and set as the default *… the post shows up on my igpu display but the linux kernel is loaded and displayed on my nvidia monitor. After stating GDM has been successfully started; nothing happens. The igpu monitor stays blank showing no signal being input, and the nvidia monitor simply shows gdm started.
[tandrias@localhost ~]$ inxi -F
System: Host: localhost.localdomain Kernel: 4.12.9-300.fc26.x86_64 x86_64
bits: 64
Desktop: Gnome 3.24.3 Distro: Fedora release 26 (Twenty Six)
Machine: Device: desktop Mobo: HP model: 82F1 v: 1.01 UEFI: AMI v: F.10 date: 03/30/2017
CPU: Quad core Intel Core i5-7400 (-MCP-) cache: 6144 KB
clock speeds: max: 3500 MHz 1: 1129 MHz 2: 896 MHz 3: 945 MHz
4: 1525 MHz
Graphics: Card: NVIDIA GP106 [GeForce GTX 1060 3GB]
Display Server: wayland (X.org 119.3 ) driver: nouveau
Resolution: [email protected]
OpenGL: renderer: Gallium 0.4 on NV136 version: 4.2 Mesa 17.1.7
Audio: Card-1 NVIDIA GP106 High Def. Audio Controller
driver: snd_hda_intel
Card-2 Intel Sunrise Point-H HD Audio driver: snd_hda_intel
Sound: ALSA v: k4.12.9-300.fc26.x86_64
Network: Card-1: Intel Device 24fb driver: iwlwifi
IF: wlp3s0 state: up speed: N/A duplex: N/A mac: b0:35:9f:04:12:bc
Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
driver: r8169
IF: enp4s0 state: down mac: 10:05:01:43:f0:6e
Drives: HDD Total Size: 2250.4GB (0.7% used)
ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
ID-2: /dev/sdb model: WDC_WD2500AAJS size: 250.0GB
ID-3: /dev/sdc model: ST9500325AS size: 500.1GB
ID-4: USB /dev/sdd model: FreeAgent size: 500.1GB
Partition: ID-1: / size: 49G used: 6.2G (14%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 976M used: 143M (16%) fs: ext4 dev: /dev/sdb2
ID-3: /home size: 171G used: 535M (1%) fs: ext4 dev: /dev/dm-2
ID-4: swap-1 size: 8.40GB used: 0.00GB (0%)
fs: swap dev: /dev/dm-1
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 43.0C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 288 Uptime: 32 min Memory: 2103.1/7986.2MB
Client: Shell (bash) inxi: 2.3.31
Any assistance would be greatly appreciated. Am happy to provide any sysinfo .
Thank you
