Hi all Im not sure if I added this to the correct thread so please forgive me if I did not. I recenlty built what I plan to be a workstation for coding, video editing, live-streaming, and light gaming(very light). Specs are as follows:
— Hardware —
CPU - Threadripper 3970x
Motherboard - Gigabyte Designaire
Ram - 32 GB(2x16) 3600
GPU - Sapphire RX 570
– Software —
I have a dual boot setup of both Manjaro Linux and windows 10(temporarily) until I get my VM’s working correctly. I would like to run windows 10 and mac os and have linux as my main os. Here is my neofetch,
OS: Manjaro Linux x86_64
Host: TRX40 DESIGNARE -CF
Kernel: 5.11.10-1-MANJARO
CPU: AMD Ryzen Threadripper 3970X (64) @ 3.700GH
GPU: AMD ATI Radeon RX 470/480/570/570X/580/580X
Memory: 1290MiB / 32040MiB
LC_ALL=C lscpu | grep Virtualization
Virtualization: AMD-V
cat …grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet amd_iommu=on rd.driver.pre=vfio-pci kvm.ignore_msrs=1 apparmor=1 security=apparmor udev.log_priority=3”
GRUB_CMDLINE_LINUX=""
cat…mkinitcpio.conf
MODULES=“vfio_pci vfio vfio_iommu_type1 vfio_virqfd kvm kvm_amd”
…HOOKS=“base vfio udev autodetect modconf block keyboard keymap filesystems”
I do have windows vm working in virt-manager but it only boots with qemu64(CPU) not kvm64. I did look around and noticed that some people said they had to add additional things to grub for a better experience. Im just stump with this and at this point dont know what to do. Please help me with whatever you can thanks all
EDIT 1- SOLUTION, I thought I had a MOBO(GIGABYTE TRX40 Designaire) with SVM already enabled because I didnt see it in the bios but once I found it and enabled it of course it worked.
EDIT 2- For whatever reason Im having issues with pasthrough rx570 gpu from Linus host to windows 10 guest
