Need help with motherboard CPU compatibility
with Christmas rolling around the block I was wondering if this motherboard is compatible with this cpu
here's the mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131340
and the CPU compatibility for it
CPU Socket Type AM2+/AM2
CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
FSB 2600MHz Hyper Transport (5200 MT/s)
and here's my CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103194
and here's the specs for the CPU
Core Brisbane
Multi-Core Dual-Core
Name Athlon 64 X2 5000+
Operating Frequency 2.6GHz
Hyper Transports 2000MHz
L1 Cache 128KB+128KB
L2 Cache 2 x 512KB
Manufacturing Tech 65 nm
64 bit Support Yes
Hyper-Transport Support Yes
Virtualization Technology Support Yes
Multimedia Instruction MMX, SSE, SSE2, SSE3, 3DNOW! Professional
Voltage 1.25/1.35V
Thermal Power 65W
as long as the socket types are the same (which they are) and it supports your fsb
well then it doesnt look compatible.. the hypertransports on the board are at 2600 and the CPU is only 2000, unless it can be clocked lower and still work
well from wat ive looked at. all the amd boards had the same thing. so it must work
it will work.
the 5200mts is for am2+ cpus
if it supports AM2 then it should support the 2000mhz Hyper Transport
