I'm planning to build a portable rig so I can take it along when I peddle from Uni to my home place on the weekends
I need a case that fulfills as many criteria of the following as possible - Small, portable - Needs to fit a Alpenfohn Matterhorn heatsink (roughly 157mm) - Needs to fit a 260mm GPU - If possible, mounts the mainboard horizontally - Prefer metal, aluminum, etc instead of plastic
The only one I've found so far is the Bitfenix Prodigy, which I want to avoid getting if possible because of the looks and materials used
That's great! Exactly the type of thing I'm looking for. Keep the suggestions coming because I don't want to decide for the first thing suggested. But definitely prefer this over the Prodigy (which was the only thing I found) so far. Thanks a lot!
EDIT: Aw, after watching the video it seems like my heatsink won't fit. It's very much the style I like though.
