If you looking for a good desktop
- what is your budget
- Do you want to build it yourself or pre-built?
- What currency and country are you in?
- What games are you aiming to play?
budget=$500-$700
build it myself or if there is a good prebuild one
currency=dollars country=US
games= like DayZ, minecraft(kinda) L4D 1+2 a bit of hardcore games
i dont know what just happened my screen started flashing and my gpu changed http://gyazo.com/d0dbd4ab42641e8ee8323d3a7a823b9d WTF?
verify with GPU-Z - screen shot it.
here a list of parts you could go with but you can change it depending on how much you want to spend. If you can get the hard drive from the notebook and reformat to use it, then you could leave the hard drive from your list if you want.
okay first my gpu what a 7000m card now it's a 6400m card WTF http://gyazo.com/d6eaa5d900227520cd00ee752b4fc49b
http://gyazo.com/81502c795f9a6ba8ef858e6b2411d668
but i cant use the amd one
try un-installing any drivers relating to amd. There may be a driver conflict.
now it says i have a amd 7400m...http://gyazo.com/99708c6f1ba0bc1ed51c0b3a0fe3ede4
EDIT:omg look at the memory http://gyazo.com/fe0a6c2816d215fe155c13247a588595
try installing the graphic drivers from this : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4132&lc=en&cc=us&dlc=en&sw_lang=&product=5193775#N337
I would actually do a factory reset. Where and when did you get this laptop?
i don't know it was a gift it said it was shipped from iraq...
Read and try this http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&docname=c02693833
The BIOS is need to be 'repaired'
okay ill try it i dont want my laptop to break i want to make sure it wont break anything
If you plan to make a computer, I would recommend this build.
http://pcpartpicker.com/p/2tiqq
