Need help with IOMMU grouping in Fedora 25
Looking for help to workaround both PCI-e x16 and x8 slots placed in iommu group 1. I've read up the ACS patch, though for this kernel version I'm not even sure if its useful.
Currently running Fedora 25 -- 4.10.10-200.fc25.x86_64
Want the X540-AT card to stay with the host OS for data backup purposes.
Any idea how to acheive this? I've tried putting the card in the x4 PCI-e slot though it fails to load.
System specs:
-- Gigabyte Z170 Gaming 7 motherboard
-- Intel 6700K
Looking to pass-through only:
8086:a12f
8086:a170
8086:15b8
10de:1b80
10de:10f0
144d:a802
IOMMU groups:
/sys/kernel/iommu_groups/0/devices/0000:00:00.0
/sys/kernel/iommu_groups/1/devices/0000:00:01.0
/sys/kernel/iommu_groups/1/devices/0000:00:01.1
/sys/kernel/iommu_groups/1/devices/0000:01:00.0
/sys/kernel/iommu_groups/1/devices/0000:01:00.1
/sys/kernel/iommu_groups/1/devices/0000:02:00.0
/sys/kernel/iommu_groups/2/devices/0000:00:02.0
/sys/kernel/iommu_groups/3/devices/0000:00:14.0
/sys/kernel/iommu_groups/4/devices/0000:00:16.0
/sys/kernel/iommu_groups/5/devices/0000:00:17.0
/sys/kernel/iommu_groups/6/devices/0000:00:1b.0
/sys/kernel/iommu_groups/7/devices/0000:00:1b.2
/sys/kernel/iommu_groups/8/devices/0000:00:1b.3
/sys/kernel/iommu_groups/9/devices/0000:00:1c.0
/sys/kernel/iommu_groups/10/devices/0000:00:1c.1
/sys/kernel/iommu_groups/11/devices/0000:00:1c.2
/sys/kernel/iommu_groups/12/devices/0000:00:1c.4
/sys/kernel/iommu_groups/13/devices/0000:00:1d.0
/sys/kernel/iommu_groups/14/devices/0000:00:1f.0
/sys/kernel/iommu_groups/14/devices/0000:00:1f.2
/sys/kernel/iommu_groups/14/devices/0000:00:1f.3
/sys/kernel/iommu_groups/14/devices/0000:00:1f.4
/sys/kernel/iommu_groups/15/devices/0000:00:1f.6
/sys/kernel/iommu_groups/16/devices/0000:05:00.0
/sys/kernel/iommu_groups/17/devices/0000:09:00.0
/sys/kernel/iommu_groups/18/devices/0000:0a:00.0
/sys/kernel/iommu_groups/19/devices/0000:0a:01.0
/sys/kernel/iommu_groups/20/devices/0000:0a:02.0
/sys/kernel/iommu_groups/20/devices/0000:0d:00.0
/sys/kernel/iommu_groups/21/devices/0000:0a:04.0
/sys/kernel/iommu_groups/22/devices/0000:42:00.0
lspci -vvvnn output:
00:00.0 Host bridge [0600]: Intel Corporation Skylake Host Bridge/DRAM Registers [8086:191f] (rev 07)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5000]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Capabilities:
Kernel driver in use: skl_uncore
libkmod: kmod_config_parse: /etc/modprobe.d/disable-nouveau.conf line 2: ignoring bad line starting with 'nouveau'
00:01.0 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x16) [8086:1901] (rev 07) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: ed000000-ee0fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities:
Kernel driver in use: pcieport
Kernel modules: shpchp
00:01.1 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x8) [8086:1905] (rev 07) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000f000-00000fff [empty]
Memory behind bridge: ee400000-ee4fffff [size=1M]
Prefetchable memory behind bridge: 00000000d6200000-00000000d64fffff [size=3M]
Capabilities:
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 530 [8086:1912] (rev 06) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
Interrupt: pin A routed to IRQ 151
Region 0: Memory at ec000000 (64-bit, non-prefetchable) [size=16M]
Region 2: Memory at b0000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller [8086:a12f] (rev 31) (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5007]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 131
Region 0: Memory at ee530000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: xhci_hcd
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-H CSME HECI #1 [8086:a13a] (rev 31)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:1c3a]
Latency: 0
Interrupt: pin A routed to IRQ 152
Region 0: Memory at ee54d000 (64-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Sunrise Point-H SATA controller [AHCI mode] [8086:a102] (rev 31) (prog-if 01 [AHCI 1.0])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:b005]
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 129
Region 0: Memory at ee548000 (32-bit, non-prefetchable) [size=8K]
Region 1: Memory at ee54c000 (32-bit, non-prefetchable) [size=256]
Region 2: I/O ports at f090 [size=8]
Region 3: I/O ports at f080 [size=4]
Region 4: I/O ports at f060 [size=32]
Region 5: Memory at ee54b000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Root Port #17 [8086:a167] (rev f1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 16
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: fff00000-000fffff [empty]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [empty]
Capabilities:
00:1b.2 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Root Port #19 [8086:a169] (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 18
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Capabilities:
00:1b.3 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Root Port #20 [8086:a16a] (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin D routed to IRQ 19
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: ee300000-ee3fffff [size=1M]
Capabilities:
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #1 [8086:a110] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Capabilities:
00:1c.1 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #2 [8086:a111] (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin B routed to IRQ 17
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
Capabilities:
00:1c.2 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #3 [8086:a112] (rev f1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: ee200000-ee2fffff [size=1M]
Capabilities:
00:1c.4 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #5 [8086:a114] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=09, subordinate=41, sec-latency=0
I/O behind bridge: 00002000-00003fff [size=8K]
Memory behind bridge: dc000000-ebffffff [size=256M]
Prefetchable memory behind bridge: 00000000d4000000-00000000d5ffffff [size=32M]
Capabilities:
00:1d.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #9 [8086:a118] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=42, subordinate=42, sec-latency=0
I/O behind bridge: 0000b000-0000bfff [size=4K]
Memory behind bridge: ee100000-ee1fffff [size=1M]
Capabilities:
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-H LPC Controller [8086:a145] (rev 31)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5001]
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-H PMC [8086:a121] (rev 31)
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at ee544000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-H HD Audio [8086:a170] (rev 31)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:a036]
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 153
Region 0: Memory at ee540000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at ee520000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Region 0: Memory at ee54a000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8] (rev 31)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Latency: 0
Interrupt: pin A routed to IRQ 134
Region 0: Memory at ee500000 (32-bit, non-prefetchable) [size=128K]
Capabilities:
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:3360]
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 11
Region 0: Memory at ed000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Region 1: Memory at c0000000 (64-bit, prefetchable) [disabled] [size=256M]
Region 3: Memory at d0000000 (64-bit, prefetchable) [disabled] [size=32M]
Region 5: I/O ports at e000 [disabled] [size=128]
Expansion ROM at ee000000 [disabled] [size=512K]
Capabilities:
Kernel modules: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
Region 0: Memory at ee080000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
02:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller 10-Gigabit X540-AT2 [8086:1528] (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X540-T1 [8086:0002]
Interrupt: pin A routed to IRQ 17
Region 0: Memory at d6200000 (64-bit, prefetchable) [size=2M]
Region 4: Memory at d6400000 (64-bit, prefetchable) [size=16K]
Expansion ROM at ee400000 [disabled] [size=512K]
Capabilities:
Kernel driver in use: ixgbe
Kernel modules: ixgbe
05:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device [1b21:1062]
Interrupt: pin A routed to IRQ 130
Region 0: I/O ports at d050 [size=8]
Region 1: I/O ports at d040 [size=4]
Region 2: I/O ports at d030 [size=8]
Region 3: I/O ports at d020 [size=4]
Region 4: I/O ports at d000 [size=32]
Region 5: Memory at ee310000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at ee300000 [disabled] [size=64K]
Capabilities:
09:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578] (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 124
Bus: primary=09, secondary=0a, subordinate=0e, sec-latency=0
Memory behind bridge: dc000000-dc4fffff [size=5M]
Prefetchable memory behind bridge: 00000000d4000000-00000000d43fffff [size=4M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Capabilities:
0a:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578] (prog-if 00 [Normal decode])
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 125
Bus: primary=0a, secondary=0b, subordinate=0b, sec-latency=0
Capabilities:
0a:01.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578] (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 126
Bus: primary=0a, secondary=0c, subordinate=0c, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: dc000000-dc1fffff [size=2M]
Prefetchable memory behind bridge: 00000000d4000000-00000000d41fffff [size=2M]
Capabilities:
0a:02.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578] (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 127
Bus: primary=0a, secondary=0d, subordinate=0d, sec-latency=0
Memory behind bridge: dc200000-dc2fffff [size=1M]
Capabilities:
0a:04.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578] (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 128
Bus: primary=0a, secondary=0e, subordinate=0e, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: dc300000-dc4fffff [size=2M]
Prefetchable memory behind bridge: 00000000d4200000-00000000d43fffff [size=2M]
Capabilities:
0d:00.0 USB controller [0c03]: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge] [8086:15b6] (prog-if 30 [XHCI])
Subsystem: Device [2222:1111]
Interrupt: pin A routed to IRQ 132
Region 0: Memory at dc200000 (32-bit, non-prefetchable) [size=64K]
Capabilities:
42:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 [144d:a802] (rev 01) (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device [144d:a801]
NUMA node: 0
Region 0: Memory at ee110000 (64-bit, non-prefetchable) [size=16K]
Region 2: I/O ports at b000 [size=256]
Expansion ROM at ee100000 [disabled] [size=64K]
Capabilities:
Kernel driver in use: nvme
Kernel modules: nvme
does your board have another slot you can put the 10gig adapter in? if not the acs patch will probably fix you up here without issues.
the patch I have on ryzen should cleanly apply to this fedora kernel -- its 99.99% alex's patch anyway so you may even be able to use the other "intel tweaks" acs patch kernel from one of the fedora coprs.
Should be fine.
Oh, and depending on the revision, there may be problems mixing pcie 2.0 and pcie 3.0 devices on the x16 lanes directly from the cpu. keep an eye on that. you may have to force pcie 2.0 across the board if the adapter is not natively pcie 3.0. There are both versions of that card.
Howdy Wendell,
Thanks for the reply!
Turns out on this motherboard, one of the M.2 slots shares the lower PCI-E 4x slot. So just needed to move the Intel X540-T1 card down to the 4x slot then move up the Samsung 950 Pro NVMe up to the top slot. And we are now rocking and rolling.
If and when you are ever in Austin, TX hit me up, you've got a drink coming on me!
Here is the final IOMMU grouping and output of the lspci -nn command. Laterz.
/sys/kernel/iommu_groups/14/devices/0000:00:1d.4
/sys/kernel/iommu_groups/15/devices/0000:00:1f.0
/sys/kernel/iommu_groups/15/devices/0000:00:1f.2
/sys/kernel/iommu_groups/15/devices/0000:00:1f.3
/sys/kernel/iommu_groups/15/devices/0000:00:1f.4
/sys/kernel/iommu_groups/16/devices/0000:00:1f.6
/sys/kernel/iommu_groups/17/devices/0000:03:00.0
/sys/kernel/iommu_groups/18/devices/0000:04:00.0
/sys/kernel/iommu_groups/19/devices/0000:08:00.0
/sys/kernel/iommu_groups/20/devices/0000:09:00.0
/sys/kernel/iommu_groups/21/devices/0000:09:01.0
/sys/kernel/iommu_groups/22/devices/0000:09:02.0
/sys/kernel/iommu_groups/22/devices/0000:0c:00.0
/sys/kernel/iommu_groups/23/devices/0000:09:04.0
/sys/kernel/iommu_groups/24/devices/0000:41:00.0
/sys/kernel/iommu_groups/25/devices/0000:42:00.0
00:1d.4 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #13 [8086:a11c] (rev f1)
03:00.0 SATA controller [0106]: Marvell Technology Group Ltd. Device [1b4b:9215] (rev 11)
04:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02)
08:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
09:01.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
09:02.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
09:04.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
0c:00.0 USB controller [0c03]: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge] [8086:15b6]
41:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller 10-Gigabit X540-AT2 [8086:1528] (rev 01)
