Well about a week ago I noticed a crack on the band of my Turtle Beach's X32s. (I have them taped with scotch tape for now) I have had these headphones for about 2 years now and they have treated me good. They were my first headphones over $100 and now that I have been recently researching headphones for a replacement I know I got ripped off badly.
Well now to the point I need a pair of headphones under $200. I am hopefully getting a new pc soon. So I will be using these for gaming(BF4). I also listen to rap on my phone so they need to be somewhat portable and have decent bass but not where they are muddying up the mids and highs. (like beats do.) The best headphones right now that I have found are the Audio Technica M50s. I know they are a little big but from what researching I have done are they are like the best bang for your buck headphones out there. But the only draw back is that they have a small sound stage. I am not sure 100% what that is but as long as it's an improvement over my current headphones I am fine with it. I think a soundstage is the whole area you can perceive in the headphones?
NOTE: They can't not have a mic on them unless it's are removeable and they mustn't require a power source like some headphones. Oh and they can't be wireless too.
I recently purchased a pair of Sennheiser 518's and overall I have been very impressed with them. They have a clear full range of sounds perfect for everything from rock to classical. They are very light and the materials the ear-cups are made from are very breathable. The only real drawback is that they leak a lot of sound (They are open-back which improves sound quality at the cost of noise isolation and sound leakage) so you won't be able to use them in a library but anywhere else they are fine. I don't listen to rap but the bass-heavy music that I listen to sounds just as clear and un-muddy as everything else I play. Sounds are isolated and crisp and the soundstage is large and immersive especially in games and when watching movies.
As far as soundstage goes its the perception of distance and that the sounds are coming from different locations. Its sort of 'scale' in terms of sound like a large soundstage would be a cathedral whereas a small soundstage would be the inside of a toilet it all depends on the headphones. Soundstage isn't an measurable thing its just the way the headphones allow you personally to perceive a sense of scale to what you're listening to. Open-back headphones will usually have a larger soundstage because the sound is allowed to escape the ear-cups and 'diffuse' naturally but some closed-back headphones are still quite good.
If you want more qualified opinions than mine I would definitely check out the headphones section on Head-Fi for great reviews and tons of threads on great headphones in your price range.
Thanks, AC1SKU11. I researched the the S518s and they don't meet the bass that I want. I keep looking though. Oh, and one more thing. Can you increase the sound stage of headphones or no?
For $200 you could get an open headphone for gaming (Pioneer SE-A1000) and another set for portability (V-Moda Crossfade LP). I have both of those headphones if you have specific questions about them.
The Pioneer may seem cheap, but it's MSRP is $150 and It sounds like a Sennheiser HD 650. The V-Moda is nice and bass heavy, and should pair well with the music you listen to.
