For those wondering about my CPU, I'm running a AMD FX8350 8-Core Processor at 4.0 GHz. So, for the money, is that a good upgrade, or should I go with something else?
If you could stretch that budget to $200 you could get a 270x which are pretty sweet cards, also there are some 270's at the 180 mark but they are hard to find...the 270x is slight better tho providing you got the room and power supply connections.
7870 hasn't done me wrong yet. With it so close to black friday it might be worth waiting. If anything, that would allow you to save up a little bit more, and do some more research.
