I got FAHClient installed, cpu folding works, but I can’t get it to start gpu folding. FAH detects the gpu, but does not have it fold
If anyone has any experience with getting it to work that would be helpful
Additional information system specs
Fedora 31
CPU: Ryzen 2700X
RAM: 16gb crucial ballistix 3200, oc to 3300, xmp on
GPU: RTX 2070
GPU Drivers: Nvidia Proprietary Drivers
GNOME: 3.34.6
terminal output when running FAHClient in terminal
FAHClient (base)
19:37:52:INFO(1):Read GPUs.txt
19:37:52:************************* Folding@home Client *************************
19:37:52: Website: https://foldingathome.org/
19:37:52: Copyright: (c) 2009-2018 foldingathome.org
19:37:52: Author: Joseph Coffland <[email protected]>
19:37:52: Args:
19:37:52: Config: /home/bedhedd/config.xml
19:37:52:******************************** Build ********************************
19:37:52: Version: 7.5.1
19:37:52: Date: May 12 2018
19:37:52: Time: 22:51:07
19:37:52: Repository: Git
19:37:52: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:37:52: Branch: master
19:37:52: Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
19:37:52: Options: -std=gnu++98 -O3 -funroll-loops
19:37:52: Platform: linux2 4.14.0-3-amd64
19:37:52: Bits: 64
19:37:52: Mode: Release
19:37:52:******************************* System ********************************
19:37:52: CPU: AMD Ryzen 7 2700X Eight-Core Processor
19:37:52: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
19:37:52: CPUs: 16
19:37:52: Memory: 15.64GiB
19:37:52: Free Memory: 1.53GiB
19:37:52: Threads: POSIX_THREADS
19:37:52: OS Version: 5.6
19:37:52: Has Battery: false
19:37:52: On Battery: false
19:37:52: UTC Offset: -5
19:37:52: PID: 26839
19:37:52: CWD: /home/bedhedd
19:37:52: OS: Linux 5.6.13-200.fc31.x86_64 x86_64
19:37:52: OS Arch: AMD64
19:37:52: GPUs: 1
19:37:52: GPU 0: Bus:38 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2070] M 6497
19:37:52:CUDA Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:7.5 Driver:10.2
19:37:52: OpenCL: Not detected: clGetDeviceIDs() returned -1
19:37:52:***********************************************************************
19:37:52:<config>
19:37:52: <!-- Slot Control -->
19:37:52: <power v='FULL'/>
19:37:52:
19:37:52: <!-- User Information -->
19:37:52: <passkey v='********************************'/>
19:37:52: <team v='232084'/>
19:37:52: <user v='BedHedd'/>
19:37:52:
19:37:52: <!-- Folding Slots -->
19:37:52: <slot id='0' type='CPU'/>
19:37:52: <slot id='1' type='GPU'/>
19:37:52:</config>
19:37:52:Connecting to assign1.foldingathome.org:8080
19:37:52:Updated GPUs.txt
19:37:52:Read GPUs.txt
19:37:52:Trying to access database...
19:37:52:Successfully acquired database lock
19:37:52:Enabled folding slot 00: READY cpu:15
19:37:52:Enabled folding slot 01: READY gpu:0:TU106 [GeForce RTX 2070] M 6497
19:37:52:ERROR:Exception: Could not bind socket to 0.0.0.0:7396: Address already in use
19:37:52:ERROR:Exception: Could not bind socket to 0.0.0.0:36330: Address already in use
19:37:52:WARNING:WU00:FS00:Past final deadline 2020-04-21T20:45:48Z, dumping
19:37:52:WU00:FS00:Cleaning up
19:37:52:WU00:FS00:Connecting to 65.254.110.245:8080
19:37:52:WU01:FS01:Connecting to 65.254.110.245:8080
19:37:52:WU00:FS00:Assigned to work server 150.136.14.110
19:37:52:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 150.136.14.110
19:37:52:WU00:FS00:Connecting to 150.136.14.110:8080
19:37:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:37:52:WU01:FS01:Connecting to 18.218.241.186:80
19:37:52:WU00:FS00:Downloading 3.09MiB
19:37:52:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:37:52:ERROR:WU01:FS01:Exception: Could not get an assignment
19:37:53:WU01:FS01:Assigned to work server 128.252.203.1
19:37:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2070] M 6497 from 128.252.203.1
19:37:53:WU01:FS01:Connecting to 128.252.203.1:8080
19:37:53:WU00:FS00:Download complete
19:37:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16430 run:0 clone:494 gen:148 core:0xa7 unit:0x000000ac96880e6e5e961d841d307bb6
19:37:53:WU00:FS00:Starting
19:37:53:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/bedhedd/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 26839 -checkpoint 15 -np 15
19:37:53:WU00:FS00:Started FahCore on PID 26917
19:37:53:WU00:FS00:Core PID:26921
19:37:53:WU00:FS00:FahCore 0xa7 started
19:37:53:WU00:FS00:0xa7:*********************** Log Started 2020-05-27T19:37:53Z ***********************
19:37:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:37:53:WU00:FS00:0xa7: Type: 0xa7
19:37:53:WU00:FS00:0xa7: Core: Gromacs
19:37:53:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 26917 -checkpoint 15 -np
19:37:53:WU00:FS00:0xa7: 15
19:37:53:WU00:FS00:0xa7:************************************ CBang *************************************
19:37:53:WU00:FS00:0xa7: Date: Nov 5 2019
19:37:53:WU00:FS00:0xa7: Time: 06:06:57
19:37:53:WU00:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
19:37:53:WU00:FS00:0xa7: Branch: master
19:37:53:WU00:FS00:0xa7: Compiler: GNU 8.3.0
19:37:53:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
19:37:53:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
19:37:53:WU00:FS00:0xa7: Bits: 64
19:37:53:WU00:FS00:0xa7: Mode: Release
19:37:53:WU00:FS00:0xa7:************************************ System ************************************
19:37:53:WU00:FS00:0xa7: CPU: AMD Ryzen 7 2700X Eight-Core Processor
19:37:53:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
19:37:53:WU00:FS00:0xa7: CPUs: 16
19:37:53:WU00:FS00:0xa7: Memory: 15.64GiB
19:37:53:WU00:FS00:0xa7:Free Memory: 1.49GiB
19:37:53:WU00:FS00:0xa7: Threads: POSIX_THREADS
19:37:53:WU00:FS00:0xa7: OS Version: 5.6
19:37:53:WU00:FS00:0xa7:Has Battery: false
19:37:53:WU00:FS00:0xa7: On Battery: false
19:37:53:WU00:FS00:0xa7: UTC Offset: -5
19:37:53:WU00:FS00:0xa7: PID: 26921
19:37:53:WU00:FS00:0xa7: CWD: /home/bedhedd/work
19:37:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:37:53:WU00:FS00:0xa7: Version: 0.0.18
19:37:53:WU00:FS00:0xa7: Author: Joseph Coffland <[email protected]>
19:37:53:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
19:37:53:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
19:37:53:WU00:FS00:0xa7: Time: 06:13:26
19:37:53:WU00:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
19:37:53:WU00:FS00:0xa7:************************************ Build *************************************
19:37:53:WU00:FS00:0xa7: SIMD: avx_256
19:37:53:WU00:FS00:0xa7:********************************************************************************
19:37:53:WU00:FS00:0xa7:Project: 16430 (Run 0, Clone 494, Gen 148)
19:37:53:WU00:FS00:0xa7:Unit: 0x000000ac96880e6e5e961d841d307bb6
19:37:53:WU00:FS00:0xa7:Reading tar file core.xml
19:37:53:WU00:FS00:0xa7:Reading tar file frame148.tpr
19:37:53:WU00:FS00:0xa7:Digital signatures verified
19:37:53:WU00:FS00:0xa7:Calling: mdrun -s frame148.tpr -o frame148.trr -x frame148.xtc -cpt 15 -nt 15
19:37:53:WU00:FS00:0xa7:Steps: first=37000000 total=250000
19:37:55:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
I also have a issue with FAHControl, when I lauch it from gnome home, nothing happens. When I use the terminal it spits out the following error
terminal output when running FAHControl in terminal
FAHControl (base)
File "/usr/bin/FAHControl", line 57
if sock.recv(1024).strip() == 'OK': print 'Ok'
SyntaxError: invalid syntax
