Need help with gaming pc build
hey i need some help never built a pc only recently decided i would like to go to some pc gaming i have been doing some research but i need help i would like to run games like BF3, Skyrim and games with similar graphics on medium to high settings i dont have a lot of money in fact i will be buying parts one at a time for the most part so far the build i like but dont know if its good or if it will work is case: cooler master HAF 912, cpu: I5-3570k, MB: ASUS P8B75-V, PSU: LEPA B550, RAM: 2x 4GB sniper G skill series HD: seagate Barracuda 1TB 7200RPM, CPU coller: cooler master hyper 212 plus, OS: windows 8 64bit please let me know what u think and if u have any suggestions please comment
That build looks alright to me, but I would really try not buying it part at a time if I were you. If your going to be buying things in peices your going to have a hell of a time when you can finally start putting it together and find one of the parts is bad and need to do a RMA. You dont want to be outside the return policy and have a nightmare to deal with. Also I don't recognise your chosen powersupply. Make sure its alteast a 80 plus certified powersupply or your just asking for trouble.
im not sure how to spell it but i could go with the  XClio 550W ATX Power Supply - $52.98 based off of the $650 AMD build right and also when i say buy parts separately i mean within the next month or so the main things i am worried about r the CPU and the VC because they are the most $ so if this build will work the way i want it to i will be buyin the VC now from Amazon
also would it make a big difference to go with the 2GB 650 ti or is the 1GB ok
