Need help with Fractal Design node 202 cooling
So I don't know how I should do this. I see some build using 2 120mm fans for the gpu, but that means removing the case's gpu supporter to which I'm not too comfortable doing.(https://www.youtube.com/watch?v=Hy_Eraep6gw Look at 4:37) I've even seen a build who managed to put a 140mm fan above the cpu cooler. How should I configure the case fans? Also, would the type of gpu I choose change anything in terms of how the fans should be set? I was going to go with a blower style gpu originally, however I would prefer to use an open aired one for the higher clock speed but I'm afraid about the temperature in such a small case. I'm also afraid of dust problems will be a problem if I don't set this right. Thanks in advance.
Hi,
sorry for the late reply,
You won't have any cooling or dust problems.
Graphics cooler doesen't matter either.
You don't need to fit 120 mm Fans below the GPU,
If you feel the need for that, you need to use your brain for finding something to put between the fans and the GPU.
In confined spaces blower type GPU cooling is better... So I guess this generation you'd be buying a founders edition card. As far as fans go look for high static pressure fans and configure them to have high positive pressure inside the case (more in flow than out flow). The number and configuration of fans isn't all that important.
