so i was just wondering on a PC for EX if you have a gtx680 and you have a 19inch monitor (1080p) and you go to a 27 inch monitor (1080p) dose your fps drop? so this is why i ask this. So the new ps4 is coming out and it says you will get 60 fps. Dose the same thing occur with a console bigger tv less fps?
This is for anyone that knows anything on the subject.
size doesn't matter only resolution
What do you mean face palm?
Upon reading your question I smashed the palm of my hand into my skull.
I understand but why? Its a legitimate question.
I won't bother explaining but I will say that the ps4 probably won't get 60fps.
This has been bugging me for a long time now. You can't bother explaining because you can't. So go face-palm some were else. And two this is a web sit form were people come and get help ok. I don't know much so i came here to get some help and you saying what you did is why is what makes me not want to ask for help.
It's because the screen size doesn't matter as previously stated. It can be a 100 inch screen or a 5.3 inch 1080 display. It won't change the fps.
