I want the PC to be able to run almost any game. I'd like it to be able to run most games, for instance, Crysis, on all max settings without getting really low FPS. It'd also be great if it was watercooled, and if it was $1500-1750 USD.
Instead of asking a bunch of silly questions, I just threw a build together for you. That is honestly pretty close to what I'd go with. It even includes liquid cooling and your operating system, all for less than 1700 USD.
That build is gonna rip anything. And don't let the all AMD scare you. AMD absolutely shreds games to pieces.
However, if you're planning on using the Adobe suite, I'd go with an Nvidia card. It's the smart choice.
