Need help with finalizing a build
http://pcpartpicker.com/p/CFsu This is the build i have came up with (i have an os and a hard drive). I have another 80$ to spend into this build and im mainly looking to game with this. What video card upgrade should i get and what processor if that is possible? Also if there are any things i should change please tell me.
I am no expert, but I think that for the cheaper builds, like this one, I would spend a bit more and get a good AMD APU and pair it up to a descrete card that will give you crossfire between the two. I think at this point the Pentiums are a bit low on power. But that doesn't mean the Pentium won't be enough for you, I'm just saying what I would do.
http://pcpartpicker.com/parts/partlist/ better build and future proof, games are gonna start using 4 cores, some already do, and you can have cross fire in the future if you want, but i would got a 500watt psu and up if you want xfire
could you repost the link?
don't see anything different from my build
cause it is your build. you can't link / partslist... it just sends them to their own parts list.
from what I see, you might be better off wioth an AMD A10 and no discrete....
http://pcpartpicker.com/p/CN3x I found this build anything you would change? I have a decent amount left over so what card is better to crossfire with and what cpu cooler should i go with to over clock?
