Hey guys
I've found a laptop in the garbage, its an Asus x55a and when I tried to turn it on there where some problems with the OS so I reinstalled windows 7 home premium from a self made ISO, I did a clean installation but now I have no drivers on it, it can't surf the internet, it can't recognize any USB device.
it is only able to read DVDs.
What can I do now??
P.S. I've installed Linux mint 17 in dual boot if it can help
go to the asus website and download the drivers
I can't connect to the internet from that computer, and if you to the Asus site it only redirects you to another site when you can download an exe that downloads the drivers for you
Under device manager right click on a device and click properties, then go to the Details tab, click on the drop down menu that say Property, find Hardware IDs and copy and paste that into your search engine of choice. That gives you a raw device id that is 60/40 right. If you want, you can copy and paste it here and I can find you what the device is
flashdrive and another pc put the drivers on the stick
nightfire Method worked thank you
