I need help with choosing the right pump and reservoir for my system with a waterloop for my Intel i7-3770k CPU. I want a pump that can pump FAST!!! I have chosen 1/2"ID(Internal Diameter)-3/4"OD(Outer Diameter) tubing. The radiator i've chosen is the Koolgate 3x120-60 Full Copper Plated radiator. EK Supremacy Full Copper is the waterblock.
My case is the Cooler Master Cosmos II Ultra Tower:
There is the insides, it's a large case so much wil fit inside.
I live in Norway and there is only ONE store that truly provide water cooling equipment. I will list a "list" of pumps that are on sale at http://www.techbay.no/category.html?category_id=161 (please click this)
- Aquacomputer D5 watepump, USB & aquabus
- AquaComputer waterpump, aquastream XT USB 12V - Ultra versjon
- Eheim 1048, waterpump, 230V
- Eheim 1250, waterpump, 230V
- EK waterpump, EK-DCP 4.0
- Jingway waterpump, DP-400
- Koolance PMP-450
- Swiftech MCP35X vannpumpe
So what pump do you recommend?
